lucas    0
My perfect pass turns on and shows speed and RPM's but i cant get it to hold speed.
any info would help.
Check to make sure the servo at the engine isn't ceased up. Take the knob and try to turn it back and forth by hand.
We were warned when we bought our boat that it is a common problem when water gets on the servo to have them cease so I built a cover for ours and (knock on wood) we haven't had any issues.
rhino89523    34
I have not messed with PP yet but as with everything I am sure I will have to at some point. To me if I had that problem I would be thinking it was something on the mechanical side of things since the gauge electrical component side seems to be reading what it needs to read and see. I'd be looking at the cable coming out of the control box that goes from there to your throttle cable first, I'd be looking at the wires that come from the helm and make sure they are connected to the control box in the stern and are not frayed or corroded, this is all just what I would probably start with just from staring at my system a little.
rhino89523    34
O.K. I am crappy with part names, when I say control box after reading Troy's response I think Servo box is probably a way better descriptive term...I was typing at the same time.
I can fix stuff, I never know what to call it and my local auto parts house loves to give me a hard time about it.
beau t    8
sorry the pic of the servo motor got lost in translation? Anyhow towards the bottom it tells you how to troubleshoot the servo motor.
The 4 Phase servo motor can make hundreds of adjustments per second to maintain the correct speed. It is vitally important that the throttle cable has free movement and the brass L Adapter (Volvo only) connecting the PerfectPass throttle cable to throttle arm can swivel and rotate smoothly.
If a servo motor is not installed in the correct location, the throttle cable may have too much of a bend or may jam against the engine cover which will cause improper operation.
Anytime you suspect the system is not controlling properly, a Servo Motor Test should be performed as follows. If servo motor test is successful, perform a linkage test on page 10.
Servo Motor Test / Auto Tighten Test
Every time you return the boat to neutral when PerfectPass is on, the servo will wind in the cable until snug in a clockwise direction. This is the normal starting point for the servo.
Each time you turn the key on or start the boat, PerfectPass becomes powered and the servo will perform an “auto tighten” function and will attempt to wind in the cable to confirm it is in normal position. (If in proper position, it will appear simply as a “click”, “click”, click”).
To check servo and servo power wire, with key off turn black knob on servo motor counter clockwise 3⁄4 of a turn. Now turn key on and black knob should turn clockwise about 3⁄4 of a turn as part of auto tighten. If it does, repeat procedure, except this time hold black knob gently to apply some resistance to auto tighten. If it rotates with good strength then it would appear servo and servo power cable are fine.
If it does not rotate or just vibrates, then a wiring phase coming to the servo may be loose or broken. Inspect all wiring around servo. Pull both white plugs apart at servo and inspect pins to ensure they are in place. Gently tug on each wire to ensure they are securely in crimp. Check at Master Module where cable is connected.
If you cannot locate problem, contact PerfectPass at (902) 468-2150.
C:\Users\mark\Desktop\Trouble.StarGazer.Mechanical.docx Page 4
lucas    0
thanks all. i will look into these tests. hopefully its an easy fix
BCanuck    1
Have you checked the GPS sensor it is sort of round and is attached with velcro. I have had issues in the past if that sensor is dislodged under my dash.
Edited by BCanuck
lucas    0
Just made it out to check on it. My servo is not locked up. It is also not turning when I turn the key on. I found out one of the two white connectors was missing a wire. The smaller connector with the two red wires. One of the right wires was pulled Out. Where do I get these new conectors? Do I need to contact perfect pass ?
Edited by lucas
I can look tonight if you want. Text me 919-464-6100
lucas    0
I ended up just soldering the wires together. I figured I shouldn't ever need to disconnect it any way.
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
