migwrx
Quiet tip exhaust, best prop for surf 2014 sv244
migwrx    0
Wondering if it's worth buying centurions quiet tip exhaust to reduce noise and what is the best surfing prop for a 2014 sv244
thk
I wondered the same about the quiet tip exhaust, but ended up putting an FAE on my boat. Love how quiet it is. Its weird, usually no spray...but sometimes it will and I think its cause of the deep V hull creating that air pocket at surf speed, I can get spray to go away by adjusting my trim plate. If you go FAE on single exhaust....to make sure your heads do not shear off (some have had this issue), instead of the cork gasket, we put 3M 5200 sealant around it (put on thick) and also used grade 8 screws (also thru silicone) since stainless is a much softer metal and maybe helped the bolts shear. FAE has not budged, I have around 8hrs on it now. Larry also came out with some special washers that are curved so if you thru-bolt (which I will do this fall), you can install these washers on inside of transom. Freshairexhaust.com
On prop, I LOVE my #1433, absolute beast when surfing and still get 40mph on top end. My spare is 1847 which is same size and slightly different cup....also is a great prop.
I have quiet tip exhaust on my 233 and I really don't think it does much....had FAE on my last boat and loved it.....very quiet!   FAE will be my next mod for sure.
The fae is the quietest.. but for fact the silent tip makes it quieter than having nothing on there at all.
For sure the tip is better than nothing, but being over the trim plate, would think most times underway, except idle, put it out of water which is what muffles it. Still has to be better pointing down tho.
Larry at freshairexhaust.com is easy to work with and great customer service and cant think of anyone with better warranty...as long as you mount it right and send them pics, if you lose it he will replace it. Normally $480...then $40 for blended welds on outside (not mandrel bent)...and $40 for baffle (tho many of the Centurions are built in and wont be removed...and unless under warranty you dont really need it anyway. But many times in the winter or spring....forums will do a group buy. If you can get at least 5-10 people together to do a group buy, you can get discount of between $50-$70 off. Think last time if at least 7 buy, then 70 discount instead of 50...we had almost 20 people this Spring and is when I bought mine. Lot of the new boats are now coming with factory FAE option and they just about all deal with this guy Larry.
LKASurfing    53
I have the silent tip Exhaust on both my 244's and did not on my 233. The silent tip makes a big difference. I would agree, not as silent as a FAE, but its completely fine for me and does not affect the wave.
    I have also used the factory High Altitude prop with no issues.
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
