mgcondra88    0
Hello, if someone can help shed some like about this, I have been looking for a replacement hydraulic and haven't had any luck. I can't tell what the part number is, but one of my hydraulics are leaking on the Wake plate above the prop.  There are two hydraulics on their.  The gauge still says it moves up and down, but I can tell it is leaking.  Thank you! I can post a picture later if needed! :rolleyes:
chadr    328
Have you tried to tighten the ram at the point where the top joins the shaft?  I have a single shaft hydraulic ram and it was leaking like yours is.  I had to tighten mine and it stopped leaking.  I also had to check the amount of fluid in the reservoir to make sure it was full afterward from what had leaked out.
beau t    8
you could have a local hydraulic shop rebuild the cylinder vs buying a new 1 if what Chadr mentioned isn't the problem,.
