Hendo
Waterproofing my cover?
Hendo    11
Hey guys. Have a 14 fx44. The cover is basically useless. It has zero waterproofing. I swear it's just a screen. Is there anything I could do to it to help?
thanks
chenige    84
chenige    84
Maybe this one. Half the price.
Clean with hot water in tub for few hours using Starbrite cleaner....then hang and dry well. Then get a gallon of 303 Fabric guard water proofer and a nice empty spray bottle (I got all on amazon). Go over entire exterior of cover 2x's and it will shed water like off a ducks back. I have 14 SV244 and had same thing going on...and followed above instruction few months ago. Also water proofed my bimini and the bimini cover.....works great on everything.
I found a gallon was quite enough for my cover, luckily I had a quart laying around to finish off the job. I highly recommend this as it will make it easier and you'll be doing it every other year or so:
https://www.amazon.com/gp/product/B000BX4VXI/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Bobby Elite    6
This is what I use, pray on with garden sprayer. The water beads right off the cover and doesn't soak in, My cover is at least 10 years old
Hendo    11
Oh that is a huge help everyone! So any other insight on "cleaning/preparing" it?
chenige    84
As long as it is clean. Scrub with a brush and sone dish soap if needed. I used a power washer on mine to rinse it well.
I take mine to the laundromat where they have a large washer. I use Woolite for soap because it's gentle. It comes out of their nice and clean.
The best results I've had are with a gallon of 303. I use a small foam paint roller to apply it and wet it out pretty good. One application is all that's needed with this method.
Yea, foam roller really helps. Forgot to mention that...I sprayed an area and then backrolled it with foam roller cause it makes sure that all waterproofing soaks into the cover and nothing is wasted. Laundromat sounds like a good idea, I didn't think about that at time. The amount of dirt that was in my tub after soaking it in hot water for a few hours with the Starbrite mildew remover was significant....I agitated the cover every 15-20mins to help the process while soaking....then I hosed it off really well and dried before applying water proofing. Made a huge difference tho, like a brand new cover. I plan to do it every spring now.
Hendo    11
So I'm getting ready to do this....  you just do it on the outside? Once or twice?
nailem    29
I have had good luck with MaryKate water proofer. I was like described above, let dry and spread out. I use a pump sprayer (were or bug sprayer) much easier and faster than a spray bottle.
http://www.boatersland.com/marykate-mk63128-fabric-waterproofer-gallon.html?gclid=Cj0KCQjwxN_XBRCFARIsAIufy1bgJLGBKVB-zfuCpGqWfkTFux2vcxmZeZFEtc9z2VIUTBX-UtgL0WsaAqewEALw_wcB
Dan gib    8
Just did mine scrubbed with soapy water rInse dry then spray with a weed sprayer and back brushed it. Turned out good maybe could have done 2 coats but it beads good with starbright. One gallon did my cover and Bimini 23' typhoon
Gdmatson    25
I have also used 303 with great results. I did 2 coats every couple years and it worked wonders!
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
