BrandinS21    11
Guys just curious if anyone has added sub floor ballast to their S21? Not sure if this is possible? Is the S226 hard tanked in the front or plug and play? Just need a few hundred pounds up front. Would be nice if it was bellow the floor. Any advice is appreciated.
Cheers
Lead? I have PnP for bow and still add another 400lbs of lead when surfing. You can fit lead bags anywhere...you just gotta tow with it and will probably want to spread around when trailering and launching depending on angle of launch,
Cwazy1    89
The 226 is hard tanked for the center ballast. There is no 'bow' tank, its just center. Its located between the helm and passenger and goes through the walkway just until it reaches the most aft bow section backrest in the bow seating area. Its a pretty small tank at just under 400 pounds.
I only run at most 50% of that tank. It would be equiv of running 100 pounds in the most fore part of the bow seating.
Edited by Cwazy1
POP bags.  I use the coolers under the bow seats for them 80lbs each side and still have room for other snacks or small items.  Thats about all those coolers are good for imo.  You might need more lead tho since you don't have center ballast.  I run center tank full plus lead fyi.
49faith    4
I do the same on my 21, but our coolers might be a little smaller because I throw a 50# bag in each side and dont have much space left. What is the total surf weight ballast of your 226? I'm not really sure what the threshold for weight is on my boat and don't want to push it past the breaking point.
BrandinS21    11
Yeah I find the coolers useless too. Will have to try the bags. Seems like just 1-200lbs is all that you need. Anymore than that gets sketchy! Had 2 big boys sitting up there once and the bow really sinks! Warning label says 370lbs max in the bow so will want to stay under that!
49faith    4
That's my concern as well. I keep 400 pounds in the boat now and 150 generally stays up front. If I'm running a full crew, I've had as much as 300 up there. It's fine while surfing but when you come to a stop it gets a little sketch. I priced out a bow filler cushion because I figured I could line up the lead bags under there and have them be out of sight. Fineline wants 650 for one though, so that's going to have to wait.
49Faith...you can make a bow filler cushion pretty easy and for $200 or less that looks great. I made one for my SV244 after hearing Fineline wanted $600. Came out beautiful.
Bought HDPE marine board online from Interstate Plastics....made a template using cardboard till it was perfect and left an 1/8" of play around perimeter (so it would be tight after vinyl added...you gotta leave a little room so don't make template too tight). Then traced the cardboard template onto HDPE using sharpie. Then I paid upholster shop to install the foam and vinyl. Cost me $150 total ($60 for 17X31 piece of HDPE....and $90 at upholster shop they gave me smoking deal cause they had leftover vinyl that perfectly matched my boat). Anyway, just an option...and that is exactly where I hide my lead. I can fit 400+lbs under the filler cushion using leadwake bags.
49faith    4
Nice. Thanks for the heads up. I was debating this but wasn't sure I'd be able to find a match for my vinyl. I guess it's easier than I thought. I'll probably go this route then.
BrandinS21    11
I have a filler cushion and haven't used it yet. Trying to find lead bags in Canada?? Will try this if I can get some lead.
I actually did the bow cushion in a silver accent color that I have on some of my trim...so worked out nice. All my pics are just over the limit, so when I can figure out how to reduce size...I will start posting pics again
Here is pic of the bow filler cushion I had made
BrandinS21...Cant remember who it was, but like a week ago, someone posted contact info for a seller in Canada area that was selling lead ballast. If you post a thread that you are looking up there for lead, I am sure someone will remember who it was.
rrd525    40
I think the Canadian company is called Driftwake?
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
