Skibumm
94 Falcon Project
Skibumm    184
Well I am at it again.  Started with the stereo delete and adding the WetSounds Bluetooth control switch.  Needed to add a switch hole for the WS.  This has now morphed into new dash panels being laser cut.  While I am at it I might as well replace the 24 year old switches.  Then decided to ditch the old fuse holders and replace with resettable breakers.  What the hell while they are laser cutting I might as well add more switches so the panels look the same on each side.  Can't have unused switches so am going to add LED interior lighting and underwater lighting.  I do have a couple of questions for the experts.  My dash panels were previously plastic and I had painted them about 10 years ago and it held up great but had a corner crack.  New ones are going to be aluminum.  I am thinking of scotch brighting them in one direction to give a smooth uniform texture then etching primer and paint and clear versus anodizing.  Looking at this route as the anodizing is more costly and the places I have found are over a month out to get me in.  Seeing as the paint has held up great previously is there any reason not to paint.  Second question is one of the switches was going to be stereo on off as I used to have it wired directly to power so I could play without the key and it simply shut off with my percko dual battery switch.  Adding the switch I could bypass having to shut off all the batteries.  The wetsounds blue tooth also has an on off so thinking I can wire it without the switch directly to power as it is easy to reach  to power off.  Any benefit to running a stereo switch?
I think we might have the same boat and same colors I am super interested in the dash panels upgrade any pictures would be great. This year I replaced three switches.
Skibumm    184
yes we have the same boat except mine is the close bow version.  Dash is identical.  I wish I had taken pics of it prior to tearing it apart.
maybe you could share a pic of the finished dash since I already know the before.  I was thinking of cutting in switches on the right side.
hey skibumm do you know where the horn is mounted I check the switch and it checks out so the actual horn must be bad If you don't know... its cool  I will track it down this weekend
Edited by jago bay baby
Skibumm    184
Mine is right under the helm about a foot away from my knees.  It is so weak that I never use it as I can whistle louder, hell I could fart louder than my horn.
Removed both side panels today as my LED strip lighting arrived.  Dang my boat is dirty behind the side boards.  Guess it will get a good cleaning now too.
slvrbulit    4
Skibumm,  Post some pictures when you can.  I am interested in this project.  I have a 1998 Elite ob that I would like to add LED lighting as well as stereo upgrade.
I will check there I am going to put in a load horn and maybe one that plays la cucaracha or the duke boys Dixie
Skibumm    184
The waterproof led striip is going to be interesting to install. The sticky tape is not  going to adhere to the fiberglass on in inside of the gunnell. I'm hoping that adhesive silicone will keep it in place. Any other suggestion on how to keep it in place?
I used (very conservatively) liquid nails and It worked perfectly
Skibumm    184
Last minute changes now.  Going to replace the clock with a depth finder with an Arimar thru hull transducer.  I know thru hull is scary but I am simply gong to remove my perfect pass paddle wheel (only used for water temp now nay way since I have star gazer with Z box.  The hole from the paddle wheel is the same size as the thru hull transducer so should be just a swap out.
Skibumm    184
The project is moving along. The dash is done. New aluminum panels, replaced all switches, added 4 new switches on the other side. One switch is the wetsounds Bluetooth switch. Replaced clock with depth finder. Tomorrow I will wire the underwater lights. Attach the interior led lights and replace my PP paddlewheel with the depth finder transducer. I would attach images but says files are too big
I am interested in how it turns out to bad you can't get pictures to post, but this is a project I will have to take up next winter as my boat goes in the water next weekend and stays there all summer
Skibumm    184
Every time I try to upload it freezes up IE.  PM me your number and I will text you some pics if you want
that looks great I am going to copy your design on the right side.  I just finished putting in a new horn -went with a regular style nothing fancy but its loud --safety first
Skibumm    184
The hole in the right is for the wires that connect my portable Satellite radio.  I have a mount that goes right above that so it is barely visible
Skibumm    184
Once finished I will send you  pics of the final.  One thing I have added is a jump seat behind the drivers seat and it was a great add.  It has storage underneath that I can put more stuff in than I thought it would hold too.  Here is a write up that the company that did my interior did so you can see the jump seat.http://www.sewlong.com/project/94-ski-centurion-falcon-xp-full-upholstery-carpet
Nick213    576
4 hours ago, Skibumm said:
You have all that space on the right panel.... is it big enough for a iPad mini?
If so that would be a perfect spot for it and just download all your music to the iPad, if you use the GoPro app it's nice to watch video on to ;)
RhuntIII    554
Listen to you. Very cool Idea. You can also down load the navonics app for you lake charts and building tracks.
RhuntIII    554
Excellent work Skibumm
Skibumm    184
I looked at that but not enough room to fit an iPad mini.
Skibumm    184
Interior accent LEDs are in and the job all but done.  Only have interior to put back in but am going to pull the boat out and power wash the carpet prior to putting it back together.  The thing I did seemed to build on the " I'm going to be doing this so I might as well do this".  All this started with a simple stereo delete.  Here's what I ended up doing:
  • Replaced Dash Panels with laser cut aluminum $89.00
    • Painted a metallic grey w/ clear coat $12.00
    • All new switches and replaced the fuses with circuit breakers $128.00
    • Added 4 switches to the right side dash panel that previously had nothing there
  • Removed stereo head unit and replaced with WS Bluetooth rocker switch $99.00
  • Added Red life form 6 underwater lights $512.00
  • Added Red LED accents under gunnels and under helm and under the closed bow (so it could have light not for accent).$16.00
  • Grand total $856.00 Yea I would never get that out of this boat but then again I don't see myself ever selling it as it is only worth maybe $10,000.  But you will not see a better looking 24 year old centurion.
Crap I just remembered that I have to add two cup holders to hide the holes in the dash from the previous stereo where the wires went to under the dash.  Oh well it never ends
nice work skibumm   when I bought my falcon I thought it was going to be my first boat and upgrade in a few years but now having her I don't think I can ever part with her having an older boat is work and I think I like it. we run her hard all summer and then baby her all winter this year I put in tower lights, int. led lights, a new fly wheel, serviced velvet drive, a few switches, a new horn, drain plug light, and traction pad on the stern. she goes in the water tomorrow for the next 4 months :)
