gravity12    83
I am rounding up the stuff to add rear ballast. I got the factory switches and see that there is factory wiring harness behind the switch panel. Has anyone had success with just plugging the factory harness into the new switches. Then just extending the factory wires in the back to each pump? I am thinking this should work. Instead of going to a sprinkler valve I would go to separate fill pumps. And separate drain pumps. I am aware of the pros and cons of areators. But have decided to use them for this install. I'm confident the system will work well for me.
Yes you can use the factory wiring, you just need to know how it was wired. What year Elite V?
gravity12    83
2006. Had the factory center tank only. I already did away with the sprinkler valve and filter. The factory wires are labeled up front.
Your drain wires should be up high in the rear compartments. Your fill is located where the sprinkler valve wiring was. You will prolly have to extend to the new pumps location. Don't forget to check the fuse panel for the location of possible new fuses needed.
gravity12    83
I was wondering about the fuses. I had heard that the hatch could be for the factory impeller pump? But not sure if I would need to add 2 new fuses for the new fill pumps I'm adding.
Nope prolly not... far right of panel.. Port and Starboard ballast has its fuses in (5amp), these should supply the power to each ballast switch your installing.
gravity12    83
Ok. I was thinking the 5 amps were for the drain pumps only. But if they are for the switch that would be good. Thanks for the help.
gravity12    83
I got everything  working.  i used the factory harnesses.  But the port switch is lit up differently.  Not a huge deal but kinda drives me crazy.  Any ideas? I think it has something to do with the ground in the harness.
Edited by gravity12
Fix
So it looks like you are running a typical aerator pump setup with dedicated fill and dedicated drain pump. correct?
Do all the switches have the same number of pins/terminals? If so, how many?
Does the one upper light illuminate when the NAV lights turn on, or just when the ballast is activated?
resko1    0
Im going through this issue on my 04 avy. The fill pumps were in the transom next to the stock center ballast pumps. I added 2 tsunami 1200's there for fill. The wires were already back there and taped off. Iirc it was brown w/blue stripe and black w/blue stripe for port and brown w/white stripe and black w/white stripe for starboard. Thick tush wires! I ran new drain pump wires since both of my drain pumps were under port seat. Under the switch cluster you will see a group of wires with tags on them. The 2 fat black wire get attached together to complete the ground. One fat brown wire is 12v lead from fuse panel. This goes to center pin on switch. The other fat brown wire to bottom pin. Top pin is for drain pump power. On the other side of the switch is a ground and 2 blue wires. This is for illumination.
gravity12    83
I bought the factory swithes for this boat from Centurion.  And used all existing wireing and harness. All of the other switches light up like the Starboard  switch.  All pumos work as normal.  It is a aerator setup.  Thanks ks for the help.
The world's tiniest most annoying light bulbs are in there. you can pop the face off and see how the lights are configured and "reroute" them to make the switches match.
Before opening the switch up and re-configuring it internally, knowing the switch style and how it needs to work, you will likely find the correct wiring diagram on the Carling web site or you will learn you have the incorrect switch for what you want it to do.
There are 3 very common switches used, each with a different wiring schematic, depending on how we need it to work.  4-pin SPDT, 7-pin DPDT and 8-pin DPDT. Some applications even require a diode or two to be wired across a couple pins.
On 1/18/2017 at 3:49 PM, c22burns said:
This Blog has been very helpful to me and may answer some of your questions.
http://centurionavalancheballastinstall.blogspot.com/2009/09/electrical.html
Dang that blog has got a lot of mileage!  At one point when it had a visitor counter it was over 20,000 visits!  Cool!
You set the stone and I went spending my money.
I found that blog before I even found this site!! It was the basis for my first ballast upgrade which led me to this site.
chenige    84
Switches have different pins. See how many yours has and figure out which power the LED when switch is on. Need to make sure it has ground also.
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
