My 2005 C4 just turned over 550 hours and I had to recently replace the computer. Bought the boat with 200 hours and have been keeping up with all the maintenance. Replaced the belt, bearings, impeller (every 100 hours), water pump, and alternator in the last 4 years and now the computer died. She runs great but now I'm thinking of stepping into something newer if I can consistently expect major items to begin to fail or need work. Wanted to know how many hours I could expect out of a motor, transmission, and vDrive before I had to start planning for larger issues. I grew up on Mastercraft's back in the 70's and 80's and could usually get ~ 1000 hours out of them before major engine work became necessary and I've seen posts that tell me some folks are getting as many as 2000 hours out of a motor. Just trying to gauge where I am in the cost cycle at this point.
Thanks - J
chadr    328
Personally, I don't think its unreasonable to get 1000-2000 hours out of a boat engine. I was told by an old boat mechanic when he was looking at my father in laws old runabout boat that had 700 hours on it that he felt that with the constant RPM's that are driven in a boat and not started and stopped like a car does, the engine should be equivalent to a low mileage car.
I have a pickup truck that has about 750 hours on it (2014 GMC half ton) and I am at 30,000 miles on it. If it is maintained and checked regularly, your boat should take care of you for many years.
As for the new displays and other technology advances that have come out, I don't know if you can guarantee that you won't have problems. They seem to give everyone issues after a few years.
That is my $0.02 for what it's worth.
Flame on!!!
Chexi    35
pcm 351W GT40s would often go 2500 hours before needing a rebuild if treated well. Of course, that was before people were surfing all the time. I expect that the higher rpms of surfing will take its toll.
bluesman280    99
I had over 1200 hrs on my 2001 Typhoon when I sold it and it still ran great, never burned any oil, and still seemed to be a solid engine.
Sent from my SM-G903W using Tapatalk
Do the required maintenance and it can go for a long time. I know of boats that were over 3000 and running just fine.
Very seldom do I run my boat over 4000 rpm, come to think of it, very seldom do I run my boat with it being in the shop. Joking aside I would think with running the 4000 rpm (less for surfing) it would be good for longevity. opinions?
Skibumm    184
2700 hours here and still running great. That being said I do not have all of the electronics that are on your boat.
daz28iroc    73
we run 2600rpm (interestingly its 2800rpm for goofy) when surfing typically this should be great for longevity of the motor. this is pretty comparable to 120kms (75mph) on the highway.
looking at a typical truck that has an hour meter on it, I think 1700 hrs is pretty equivalent to 100,000kms. at a conservative 60 kph average over the distance.
so 3,500 hrs is what I would expect to see as a minimum before a rebuild is a good idea, or 5000 hours and its required.
yeah, I don't see why they can't go 3500 with proper maintenance. With the right prop, etc., it's not much strain on the engine.
Edited by DrNate
gravity12    83
This is interesting. My boat is between 3000 and 32000rpm. For surf of wake boarding speeds. From the sounds of it that's a little high? I thought it was pretty good plus it holds speed well at that range. I have the 537 prop and only 1100lbs of ballast.
chenige    84
4000 rpm. Over 2500#.
bluesman280    99
Our SV233 runs around 3200 rpm at 11.6 MPh with 2350 lbs ballast.
Skibumm    184
Being a slalom tug and not a fast one at that I run mine close to 4000 most of the time which is pulling a skier at 34.2
thats about what my 230 turns with about 3k ballast. I've seen some high rpm numbers lately. I've never loaded mine more than 3500lb I bet it would scream and struggle with 4K plus ballast
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
