jayz-23    12
Hey Guys,
I have an 07 Enzo SV230.
The original prop was an Acme 857,
Last year I upgraded to a 1579 and worked great, this year first run out I trashed it.
Local place has both another 1579 or 1433 available,
Will I gain or lose going to a 1433?
With an extra 1/2" diameter you'll gain a bit of hole shot but probably the same top end. The 1433 might cause some gel burn as it will be within 1/2" of your hull.
Well the specs are:
1579: 13.5x14.25 with .105 cup
1433: 14x14.25 with .105 cup
If you have the clearance for another ¼ inch, and the 1579 had some RPM to spare, you should get slightly better performance with the 1433, and turn slightly less RPM at same speeds. If you were not able to redline with the 1579, you might not be able to spin the 1433 as good though, and may lose performance. All things being equal, the 1433 will perform slightly better due to less slip from greater surface area at slightly lower RPM.
Definitely make sure you have 3/4" or more clearance from blade to hull. Otherwise, as Dreamer said, very good chance of gel burn and even worse
jayz-23    12
Ok, thanks guys.
Does anyone on here run a 1433 on an 07 Enzo for some confirmation of clearance tolerances?
Ok, thanks guys.
Since these boats are hand made, you have to make sure for your boat as each boat has different individual clearances.
jayz-23    12
How much clearance do you have now with the 1579?
I dont know, theres no prop on the boat now and the 1579 is trashed
The 13.5" diameter on my 07 SV230 only had 1/2" clearance to the hull.
Do you still have the 857 that you can mock up and measure?
jayz-23    12
I will this week as its actually getting repaired as it was repairable as it had minor dog ear that was causing vibration. So ive been sitting with no props for few weeks. Good thing its been mostly rainy
super1990    18
I am pretty sure the 1433 is what I ran last year. I did get the burn on the bottom of my 2008 Enzo SV230 but it was minor. I really noticed a difference with the bigger diameter prop. I am now running the 1617 which is even a lower pitch and it works great for surfing but it does rev a bit on top end.
jayz-23    12
Im curious of the 1433, i just put the 857 back on which is 13.25" dia and I have 7/8" of an inch clearance from highest point of a blade to hull. Notices i had some marks right above but dont think its burn but actual goughes from trashing the last prop and kicking a rock around. So with the 1433 i would add anoth .4 of an inch...that seems like to close for comfort and may just have to go with a 1579 again
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
