pwarning
Audio help for someone brand new
pwarning    5
I have a 2008 Enzo SV230 with the skylon double up tower. Boat came with the Sony head unit with built in amp powering the in boat speakers and a remote mounted on the driver console.
My first issue, whenever I hit a wave or small bounce (I am not slamming into wakes), everything turns off and comes back on. I am assuming loose connection somewhere but has anyone had this issue and solved it?
#2 Just got a great deal on Roswell Vamp Pro Spin speakers and a Rockford Fosgate 5 Channel M600 Amp. Speakers have LED lights in them. My first thought was to install them to the sub channel but I have been thinking that might become very annoying. My second thought was to add a switch somewhere so I could choose always on or powered by sub. I will also be installing a secondary battery with Perko switch.
I have been reading as much as I can on this set up but am a little confused on a few points.
I would like to have volume control over in-boat and tower separately. I am on a very tight budget but I also don't want to waste money by buying cheap quality and having to replace in the next year or two. I got the 5 channel amp so that I could add a sub next year and hope to continue adding to the boat each year.
Can anyone walk me through (treat me like an infant on this one) how to set this up? If there is a thread that already covers this, direction to that thread would work as well.
Thank you in advance for all your help.
For the separate volume control, get a Wet Sounds ws-420, there is also a Bluetooth version of you want to add Bluetooth control
#1 could be poor wiring connection or loose connection internally of the head unit. I would solve this before getting too far into upgrades. Add additional gear can compound an issue
#2 a sub chnl on a 5 chnl hybrid amp is just that, a low-pass sub woofer chnl. You dont want to try and drive full range tower speakers from a sub chnl. I would dedicate the 5 chnl amp to the in-boats and future woofer. Then, get a dedicated amp for the tower speakers.
Zone control.............simple and effective, you cant beat the kicker ZXM-RLC. Next step up would be the new Wet Sounds WS-220 4 zone zone control thats releasing. The 3 zone WS-420SQ or BT would be the next level up, as it has a dual equalizer for tonal adjustment of the in-boats independent of the tower speakers.
pwarning    5
Wylie. So should I completely disregard the built in amp in the head unit that is currently powering the in boat speakers? I was hoping that I could keep using that for now.
All head units have internal amp, in order to drive speakers. The difference is the output as compared to an external amp. Head units typically only deliver about 15 watts of real power for a speaker. This is WAY to little for a speaker that needed to compete with wind, water and engine noise in an open air environment of a boat. 2nd, if you are going to add a sub later, you really want some extra wattage behind the full range in-boats so they dont get overrun by the bass. 3rd, in order to have effective zone control, all the speakers need to be on an external amp.
You can keep the in-boats on the head unit for now, but the system is going to quickly outgrow the head-unit when you implement the 2nd phase. Just plan ahead in regards to amp space and cabling.
pwarning    5
Wylie.
Thanks. That makes sense. I've read a lot of your posts recently and you have a ton of info on this site!
chenige    84
This is my setup. No subwoofer but it would just be another amp hooked to the WS420 and then speaker wires from the WS420 to the sub.
Edited by chenige
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
