byerman    5
I am traveling away from home. There was a great mechanic at Lake Tahoe that finally repaired my ramfill drain valves by replacing them. I just realized that the LED underwater lights don't work. I am unsure if the repair is related. I can follow the blue wire with the white stripe from the 2 LED lights to the dash but there are so many wires that I can not trace it further. Any ideas?
Hard to say with out seeing any pics. If you started at the lights, did you trace back two wires? you could always trace the wires back to a dry location cut and hook to a separate 12v source. before you do that check all terminations at the switch, fuse panel etc. Do the tug test, pull on the wires just a little bit for loose connections. good luck.
Also the polarity have to be correct LED's, keep that in mind.
byerman    5
I found that it was as simple as choosing the lights under the dealer set up option.
Kiwi042    4
When one of mine stopped working and they replaced the LEDs themselves. One appears to have moisture in it now so I'm sure it will be on the way out soon.
