That picture makes the cockpit look smaller than it is. I've driven the white and black S211 above with the whale on the front. It's similar size to a axis A20. Maybe a bit bigger.
CrewAdmin    192
SURF WAKE AND REIGN SUPREME WITH THE NEW 20+ FOOT VALUE CLASS TOWBOAT
Supreme Boats reveals the 2016 S211, a new value class surf/ wake boat with World Class performance, cool customizable style, functional simplicity and strong construction.
2016 Supreme S211 Specs[/size]
Length: 20’ 11"
Beam: 102"
Draft: 30"
Weight: TBD
Fuel Capacity: 43 gal
Seating Capacity: 12 People
Ballast Capacity: 1000 lbs STD + 1975 lbs OPT = 2975 lbs
(Merced, CA) - The 2016 Supreme S211 measures just under 21 feet while packing the World Class performance and accommodation of a much larger towboat at a huge value. S211 performance begins with the wave-making Deep-v Hull, complimented by QuickFill Ballast, Plug and Play Ballast, an optional center ballast tank and the available QuickSurf System all pushed by Crusader Engines from PCM with S-Force. This new model from Supreme Boats is small, but supremely cool inside and out. The seemingly traditional modified v-bow offers big wide-bow comfort. Colors are customizable so each S211 has a unique style. The S5 Tower by Skylon adds another level of cool to the S211 along with simple, but functional new overlock fold mechanism. Built with the goal of strength and longevity in spite of its price point; the Supreme S211 benefits from a host of premium materials and components as well as production processes. Find your nearest Supreme Boats dealer to Surf Supreme, Wake Supreme and Reign Supreme today.
World Class Waves & Wakes
The Deep-v Hull has an aggressive V that follows the length of the running surface to allow the S211 to sit deeper in the water and displace more water with less weight. With 1000 pounds of QuickFill Ballast that fills in a couple of minutes, optional 150-pound center tank as well as available bow and stern Plug and Play ballast totaling 1825 pounds; the S211 can be weighted with as much as 2975 pounds of ballast right off the factory floor. Add QuickSurf to this equation and weighted completely even you can make an amazing wave on either side with the push of a button. But water sports performance is only the beginning of this story.
High Performance
The Deep-v Hull is the foundation of the S211’s wake performance, but the seamless integration of handling and power make it a World Class Towboat. This hull design also creates a better rough water ride by cutting through the chop with its acutely angled keel. With the perfect placement of the new large SmoothTrack Tracking Fin the S211 stays straight even with a progressively cutting rider in tow. The 52 square inches of fin surface area also act as an amazing pivot point under the S211, significantly improving slow and high speed handling as well as navigating in reverse. Powered by GM Marine Crusader Engines from PCM, the S211 comes standard with the forceful EX3 engine, optimized by a 1.72 X 1 gear reduction and specific propping for instantaneous take-offs. You can upgrade to the GM Marine H5DI or H6DI by PCM with S-Force for even more pulling power. Supreme Force (S-Force) is torque optimized propping and gearing to fully utilize the extremely efficient power of a direct injection GM engine. With 5 years of warranty these engines provide as much piece of mind as they do mind-blowing performance.
Cool Style
You will be proud to be seen in this Supreme. The modified V-bow is wide, deep and welcoming yet follows a traditional style. Supreme’s new Skylon S5 Tower with patent-pending overlock adds to the style of the S211 with its forward sweeping lines. The tower also introduces a black wrinkle-coated element that is matched on the exterior by a new fresh air vent and throughout the interior by new grab handles. The body lines along the sides of the boat are stylishly subtle, but can be punched up to aggressive with gel coat scheme and color choices. From the dock you will notice the intricate gel coat pattern and stylized graphics. With the choice of two distinct gel coat schemes and 25 colors, including 12 available metal flakes, you can make the Supreme S211 uniquely you. The customizable cool spills into the interior with an abundance of available colored and textured Spradling vinyl accents throughout. Customize your dash with colored accents and stitching. The Supreme S211 interior also houses big beats with a standard Clarion Sound System complete with 6 WetSounds Speakers. The flooring options in the S211 range from the standard Friction Snap-out Mat to a Luxury Logo Carpet to the cool Supreme-branded non-skid flooring from Gator Step.
Cool Style
Strong Construction
The Supreme S211 benefits from high quality materials and production processes. Every Supreme boat comes with a tandem axle BoatMate Trailer equipped with disc brakes on both axles, aluminum wheels, LED lighting, swing tongue, stainless retractable transom straps, aluminum fender steps, winch and strap. Supreme interiors are covered in tough beautiful Spradling Marine Vinyl and sewn with incredibly strong GORE® TENARA® thread made by GORE-TEX®. The S211 interior is seamed with a combination of triple and double stitches that add to the cool look of the interior while increasing the strength and longevity. The unibody construction approach Supreme uses to build their boats sends that strength and longevity through the roof. The Supreme hull, stringers, sub-floor, floor and deck are fused together with Plexus. Plexus changes the molecular structure of the fiberglass and makes two pieces one. Supreme also uses a reverse shoe-box design to join the deck and hull. These processes are where Supreme boats derive a lot of strength and quiet operation. This quiet is amplified by Supreme Sound Suppression Technology (SSST). A material laminated into the hull of the boat, SSST silences prop thrust vibration and water noise for a comfortable quiet ride.
Schedule a test ride with your local Supreme Boats dealer to Surf Supreme, Wake Supreme and Reign Supreme behind the 2016 Supreme S211.
About Supreme Boats:
World class towboats that reign Supreme. Supreme boats are World Class performance, style, simplicity and strength built to help water sports fanatics reign supreme on the water at an extreme value. To learn how you can wake, surf and reign Supreme visit www.skisupreme.com
About Correct Craft:
Celebrating 90 years of excellence in the marine industry, Correct Craft is a Florida-based company with global operations. Correct Craft holds a controlling interest in Supreme, Nautique, Centurion Boats, Bass Cat and Yar-Craft boat companies, Pleasurecraft Marine Engine Group, and Aktion Parks. For more information please visit www.correctcraft.com
VIDEO:
Just to save y'all some time searching:
Could save even more time by not bothering. LOL. They're definitely not putting much money into the marketing for the Supreme lineup.
rockballer    162
Doesn't look too bad. Looks pretty small.... But I guess it's only a 20' boat. that might explain it. Price point should be the number 1 factor for this boat.
rockballer    162
really liking the lettering style on the side with the color. Looks really nice. Would be cool to see the orange in all metal flake. That would make it really pop.
Lak3surf3r    714
If that boat is under 50k fully loaded then its a good deal, if not they made another big mistake (after their terrible marketing). They need to stop using quicksurf in these release videos as well. It makes a terrible wave and comes off even worse on film. It is a good looking boat though, I like it better than the s21 styling and shape
Edited by nasmith342
Dandy    43
I personally thought the shot around 0:37 was alright...things looked good there
gravity12    83
I like everything but the orange gel on the nose. Looks like fish lips. Nice boat
Edited by gravity12
Stretch    409
I just can't stand how grey it all is. Cool boat though. You could probably tow it legally! :p
Edited by Stretch
I like the the smaller version better than the 238. Think the snub nose fits the smaller boat better.
Depending on price It could be a homerun for supreme?
Don't think that boat in the release video had the center tank cause it didn't have the stupid footrest cover over the ballast 90 right at the helm. Unless they fixed that terrible design??
Come to think of it I didn't even notice it anywhere on the 238 either.
Lak3surf3r    714
Taking it out now!
211 or 238 must be the 238 right ? can't wait for an honest to goodness review. have fun for us guys at work.
The cockpit is way to small for us, with the capacity really not sure where you would seat 12 people?
Carter13    69
This made me bust up bud. :clap:
  • Like 3
the boat makes me think of charlie brown and the great pumpkin.
Lak3surf3r    714
Oops i posted that pic in the wrong post lol
Go check the 238 post for an actual review though.
demo9asx    23
Too much wasted space in the bow on that 211. Cabin seems really tight. Yay for washy wave!!
Lak3surf3r    714
I cant wait to see what this boat in action fully weighted. It was confirmed that it will be a sub 50k boat in AZ and if it can throw a decent wave this will be a new into into the market for a lot of people.
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
