TwistC3    7
What batteries are you all running these days, conventional or gel? thanks,
Dont know anyone running a gel in a boat. By chance do you mean AGM? I like both for different reasons. Cant beat the $$$ to Ah ratio of a good quality LAWC but for a large house bank thats going to see repeated deep cycles, AGM's will last longer. Also consider pairs of 6V GC's for a house bank. just need a good maintenance regiment.
I installed 2 6v batts for the stereo bank and i'm extremely impressed with them. I've played them for entire weekends and never once had any issues. Of course I shore charge them when home and make sure that they are full of water but so far heads and tails better than my single 12v bank was.
sallen    3
Sorry for hijacking, but this is kind of along the same lines... those with a dual battery setup, do you have a starting battery and a deep cycle, or two starting batteries, or two dual purpose? My ss230 came with two starting batteries and number one is already worn out in less than 2 years. Wondering if I should switch to a deep cycle to run everything else and moving the other starting battery to be primarily used for starting now. Any thoughts?
@ Sallen,
How is that #1 battery used? Is it your main cranking or a dedicated house battery? Is your dual bank setup using a traditional 1/2/BOTH/Off switch or the dual circuit plus switch with a VSR? Do you have a shore charger or access to A/C so one could be used?
sallen    3
Battery 1 (the one that doesn't hold a charge now) was the main cranking battery. Battery 2 (also a starting battery) was being used as a house battery. The switch is off/1/both. I am pretty green with electrical so not sure what the VSR is? I trailer my boat is it goes in the garage after every use and I frequently (though not always) remember to put it on a trickle charge afterward.
Its odd for a marine cranking battery that was used as a cranking battery, to reach its end of life in 2 seasons. What type of charger are you using?
sallen    3
Battery Tender trickle charge. And yeah, very odd. But should I replace it with another cranking battery or move the #2 battery to that position and then put in a deep cycle as the house battery?
For a switch and voltage sensing relay setup I like to have a cranking battery for starting and a deep cycle for the house side. As to moving the existing cranking from the #2 house side to the #1 cranking side is a tough call without knowing the condition of that battery. If your trickle charger is not a multistage smart charger then I would be careful with how long its left on to charge.
sallen    3
Sounds like to be on the safe side that I might want to consider 2 new batteries? Cranking and deep cycle? And just get it over with? FWIW that Battery Tender is a smart charger and doesn't over charge. It switches to maintenance mode when the battery is fully charged.
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
