dmigas    3
How hot should the wheel bearing hub get? The last tow home about 10 miles and 50/50 city versus freeway driving after getting home they were almost too hot to hold on to. Not sure if 'hub' is the correct term so here's a picture. The hot area was inside the lug nuts, which were hot too.post-5920-0-24597100-1435642083_thumb.jpgpost-5920-0-24597100-1435642083_thumb.jpg
TL68    40
Give the trailer brakes a look over. Were both sides hot? Same side dual? You could have a brake shoe, or shoes dragging and maybe needing changed. Also, look at your calipers, I've had those go bad on a vehicle after doing a complete brake job. It go so hot I could smell the brake shoe burning. Fill the trailer fluid reservoir,if needed. Grease the bearings while you have everything apart. Good luck.
boatnut    230
And make sure the brakes are bled properly, also what type of brearings do you have, oil bath? Greaseable/bearing buddies, vault?
Skibumm    184
To answer your question not as hot as you describe. I pulled mine 6 hours to Lake Powell and you could still touch anywhere on the wheel or hub. The hub was warm but not hot at all. In ten miles I would also bet on brakes. Jack up your trailer and spin your wheels because if it is bearing failure causing that much heat in that amount of time you will be able to tell as your wheel will be all over the place if bearing are causing it and they will be hard to turn if brakes are locked up. I replace bearing every three years as it is cheap and I do not want to have a failure during a trip.
WickedC4    12
dmigas, when I pulled my drums off to check why my hubs where getting hot this is what I found....
Cheap glued on drum shoes.....
Everyone is on point with answers. Good job guys. Also there is a safety cable at the tongue of the trailer. My new trailer has a release switch underneath, I check it every time now. Anyway if the safety cable has been pulled it will engage the trailer breaks.
boatnut    230
Normally if that safety cable is pulled hard enough, it breaks a little plastic hook thingy, and you have to replace it, the could be a dead give away as well, but don't over Grease those bearings either, as for bonded shoes they are not a bad thing, because rivited shoes, when they wear down, can grind thru your drum
TL68    40
brake shoes are better than fried bearings. don't skimp on shoes. Get a good brand and have the drums turned, you'll will be thanking yourself, knowing that things are done right and depending on how much you tow, you may never have to do that job again.
dmigas    3
Great stuff. Thank you all for the tips and advice. I need to take the time and just do all the above, go through and check everything. It clunks pretty good too when starting from a dead stop... there was a post about that not too long ago.
From what I can tell they are Teailer Buddy Axels by LIF P
All four hubs were equally as hot.
boatnut    230
Clunk could be bad spring in actuator, or. Air in the system
TL68    40
Also could be your hitch making the noise. After stopping, the tongue on my boatmate trailer clunks pretty loud.
Your axle, hubs and brakes were probably manufactured by UFP, or Unique Functional Products. You may be able to find brake and/or bearing/hub manuals online that could be helpful.
Throughout the course of your investigation, I would definitely bleed all the old fluid out, replacing with new. If they're running that hot, it is possible that you have boiled or significantly degraded the brake fluid.
bluesman280    99
I suspect you have probably solved your issues, but I have had problems in the past with the quick coupler on the removable hitch on our last boat.
The quick connect coupler wasn't working properly and thus the brakes were dragging sometimes. The problem was intermittent which made it a bit of a pain to trouble shoot.
enzo101mo    98
I one time was in a hurry to get to the lake swung my trailer tongue around and dropped in the pin and drove to the lake. I told my Wife the trailer feels like it dragging. By the time I got to the lake I could here clanging go on, I had pinch the hydraulic hose and burned up the bearings and the Brakes
uhhhmmmm... oops!
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
