IROCNParts    108
So being proactive I purchased a new drainmaster valve to have as a spare because these first gen valves seem to have issues. While doing some greasing I came to an interesting conclusion.
The rams all work great when they are standalone. I cleaned/greased them as per the drainmasterr specs and even tightened the bolts to 20" (inch) lbs as per spec. And was still having issues. Sticking, slow opening, some so stuck they wouldn't open.
I tried removing all the flanges and gaskets and the valves opened flawlessly. So I re-assembled and retested and sure enough they began to fail! The new ones however, did not.
So I retesting torquing to about 10" lbs and found the failure rate dropped. So I don't know if I'm missing anything here but perhaps these older valves just aren't good enough for these applications?
I'm using dow 111 grease, lubing the f-*k out of them. New gaskets, proper, and if not, even lower torque specs.
Anyone else have any insight? I have not tried to get grease "up top" into the gearing. Going to try that tomorrow.
Thanks guys!
Ahhh, technology at its finest.
So you tried the new valve (different design?) tightened at 20"lbs and it worked perfectly?
And the old ones work "better" @12"lbs, but not as good as the new one?
IROCNParts    108
I haven't tried the new ones (gen2) yet. I only got a new gen1 valve. go wash your mouth out with soap junk. I gotta think the water pressure against them is too high and perhaps is binding them internally. they're initial design is for motorhome / rv septic tanks. so they're deisgned to hold back water, but at 30mph the water pressure is pretty high. I ciuild see that potentially causing issues.
I dunno. I'm thinking too much
boatnut    230
I don't know about pressure, but when you have a black tank full of poop and TP , it's gotta have a fair amount of pressure behind.... :o
[/quote only about half pound of pressure per vertical foot of liquid
boatnut    230
I don't know about pressure, but when you have a black tank full of poop and TP , it's gotta have a fair amount of pressure behind.... :o[/quote only about half pound of pressure per vertical foot of liquid
Is that from personal experience??? B)
Sort of I am a union steam fitter so pipe systems are what I do for work. I rounded up so it would be easy for you to figure. Does not matter the size of the tank. It is called head pressure so when we test large tanks from the bottom side we must also add in head pressure. For example lets say you have a 10 foot tall tank that you must test and fill from the bottom with a test pressure of 130 LBS you would have to bring the system up to 135 LBS for the tank to see a 130LBS.
IROCNParts    108
what kind of pressure do youthink the rams see at 30mph
IROCNParts    108
if anyone is curious the gen2 valves are made by Valterra. Part # e40a
If you're having issues, talk to your dealer about a retrofit with the new valtera valves. Could be covered under warranty. The new valves are much nicer. That being said, none of our boats have had issues with the drain master valves either.
IROCNParts    108
is there anything that needs to be done when retrofitting or is a simple swap in swap out? Plugs are the same I noticed. Everything else looks the same too
Varies from boat to boat, but for all intents and purposes it is a straight forward swap. I should clarify, the "upgrade" to the newer valves, in your case, would likely not be a warranty covered item, but replacement of the current malfunctioning valves could be. I think there is an effort being made, however, to push to retrofit the earlier first gen models with this newer equipment.
IROCNParts    108
good news! Great to hear! Thanks for the info!
Lots not sure what the formula for that would be but it is far more pressure than they ever see in an RV. You would think Centurion would have their own valve design built to handle the job instead of just using what was out there.
IROCNParts    108
I should probably mention the first time I put my boat in the water the valves didn't function correctly. I purchased it new. And it was a factory order
Knock on wood.....I have yet to have any issues on my 2013 now in it's third season and just about 200 hours (drought killed us last year).
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
